servo help!!!!! please
Reply
Old 04-10-2004, 10:24 PM
goose2151
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo help!!!!! please
I have a plane with the following problem:the servos do a lot of unwonted moving. The setup is a GWS 4- channel rX, two Hs-55 Servos and an electrifly speed control with BEC. what is causeing the movement help (is it the BEC or etc.) help!!!!!!!!!! I haven't even gotten this plane off the ground and there are already problems. help!!!
goose2151 is offline
Old 04-12-2004, 01:18 AM
inferno6688
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: servo help!!!!! please
sounds like ur getting some sort of intereference.
is ur antenna fully extaned? check if there are breaks in the antenna.
have u got another reciever u could try? just stick in another rx in and see if there are still problems. again if u can try another speed controoller, that will help u narrow down the problem.
check to see if there are any metal bits touching.
hope that helps!
[8D]
inferno6688 is offline
Old 04-12-2004, 09:02 PM
goose2151
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could running the antenna through foam cause interference?
Old 04-12-2004, 11:06 PM
rhd-RCU
My Feedback: (36)
rhd-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do the servos follow the transmitter stick movement at all?
rhd-RCU is online now
Old 04-13-2004, 09:03 AM
mulligan
mulligan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the interference present only when the motor is running? If so, did you properly add capacitors to the motor?
mulligan is offline
Old 04-13-2004, 10:19 PM
goose2151
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes
it seems to be the worst when the motor is running. The servos only twitch a little when the motor is not running I will check the capacitors I did not add all the capacitors that came with the speed control because the motor already had two of them one it so i just added the one.
Goose
