Programmer - Pulse Measurement Acceptable Flux
Reply
Old 04-11-2004, 09:36 PM
sillyness
My Feedback: (25)
sillyness's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Programmer - Pulse Measurement Acceptable Flux
What's an acceptable fluctuation when the Hitec programmer is measuring the pulse the RX is getting?
Is 1, sometimes 2 microseconds OK, or that too much fluctuation?
I probably never would have noticed, but the 8611 with a 3" horn moves a good bit with a 1 microsecond change. I thought I was getting interference, so I hooked the programmer up and saw the small fluctuation. My 5945's seem to have about a 2-3 microsecond deadband (desirable for ganging!), which doesn't show the RX pulse flux clearly.
Basically, I want to know if the small flux is noise or if it's normal operation.
Thanks a gaggle,
Jason
sillyness is offline
Old 04-11-2004, 11:29 PM
Phil Cole
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Programmer - Pulse Measurement Acceptable Flux
1 us is probably right at the resolution of the transmitter, so you can expect some variation, depending on how close your stick happens to sit to a quantising boundary. This would happen whether you're using PPM or PCM.
If it's a PPM transmitter, it may be the noise in the receiver is enough to give you 1 us of jitter.
Phil Cole is offline
