Multiplex 9 channel synth Rx has arrived.
Reply
Old 04-20-2004, 05:07 PM
JohnMac
JohnMac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Multiplex 9 channel synth Rx has arrived.
Well "all things come to he who waits" and my Synth Rx has arrived. Very interesting it is too. As well as obviously having the ability to seek the strongest signal, lock onto it and confirm it as correct, it has a number of other interesting facilities. Firstly it is an IPD Rx but you can turn the filter off temporarily to do the range tests, then when satisfied turn it on again. Like the previous 12 channel IPD recievers you can plug 2, 5 cell batteries in and it will monitor the performance of each, and keep each working at its optimum.
Even more interesting is that it provides an error counter (low voltage, interference, and low field strength), and that at switch on if the voltage is below 4.4v it spits its teddy out and won't play any more until the voltage is raised above 4.8v. This is a potential model saver!
Hey and after all that it works as a receiver too!. Totally free of drama as expected.
Changing the frequency is quick, easy and totally foolproof. I just need a extension programming switch now as this Rx is ideal for models where the Rx is buried.
JohnMac is offline
Old 04-21-2004, 03:01 AM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Multiplex 9 channel synth Rx has arrived.
John, how does the error counter give you the info - blinking led? Does it tell you how many of each type of error or just the total of all errors?
H
HarryC is offline
Old 04-21-2004, 03:12 AM
JohnMac
JohnMac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Errr... I'll have to read that bit again. I think its just a total of all errors but there is some info about what the blinking LED means.
JohnMac is offline
Old 04-21-2004, 01:39 PM
mrigo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a RX-12 Synth DS IPD!
From Operating Instructions:
The receiver features three internal error counters for the following errors:
Low voltage.
Recepcion blind spots (severe field strength fluctuations)
Signal interference
The LED displays the sum of the errors in the three error counter as soon as the error is detected:
LED Code 6 --------------- - 1-9 erros
LED Code 7 ------------- - - 10-29 errors
LED Code 8 ----------- - - - >30 errors
Miquel Rigo.
mrigo is offline
Old 04-21-2004, 02:56 PM
Wiker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those who are interested can download the instruction manual here:
[link=http://www.multiplex-rc.de/cms/vorschau/upload/d_anleitungen/rx_9_12_syn.pdf]http://www.multiplex-rc.de/cms/vorschau/upload/d_anleitungen/rx_9_12_syn.pdf[/link]
Wiker is offline
Old 04-22-2004, 06:57 AM
rorywquin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: JohnMac
What happens if the voltage drops below 4.4v while you are flying ?
rorywquin is offline
Old 04-22-2004, 07:15 AM
JohnMac
JohnMac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rorywquin
ORIGINAL: JohnMac
Rory, I don't know the exact voltage that the Rx stops working, but when you reach that point you crash of course! This is the same as any other Rx. There is no way the Rx can let you know that there is a problem with the supply voltage and this is why I always use two 5 cell batteries. I have had batteries fail in flight.
John.
JohnMac is offline
