JR XF631
JR XF631
Does anyone know if you can run flaps with this radio? I know it is suppose to handle some type of flap mix.
Trying to fly a plane of course with flaps, with this radio.
Thanks, (rookie question)
RE: JR XF631
The short answer is yes. There is a seperate dedicated flap switch and if you have a seperate flap servo it is just a straight forward connect. You can also use the flaperon setting which will partially deploy your ailerons as flaps.
Just follow the instructions in the book (they can be a little confusing) with Tx and Rx on to make sure you are getting the movement you require.
Cheers,
Colin
Cheers,
Colin
