GP extra300s 60 servos?
Hi , will a Futaba S3010 Standard High-Torque Servo ,72oz servo do on the rudder ,( pull pull or not ? )
or can i use a S3004 ?? (44oz).
Also will two Futaba S3004 Standard Ball Bearing Servo's on the elevators
do the job on a GP extra300s 60 ?????
Will use the S3004 for ailerons too ?????
As you can tell i have 4 , 3004's lying around !!!!
p.s Engine G90,have counterbalanced elevators and increased stock rudder size ~3/4"long .Shortened fin a bit,bigger C.Bal.
surely the C.Bal's has lessened the load a lot ???
cheers for your advice , torp.
RE: GP extra300s 60 servos?
Cheers Redrum thanks for your imput.
Will go with this set up .
Must get s3010 now !!!!
torp
p.s. bloody good to get advice here at RCU from you good buggers,when the likes of myself are entering
into the unknown at times.Makes critical decisions easier !!!!!
torp
