Will any Rx/Tx work with BEC?
RE: Will any Rx/Tx work with BEC?
No you do not need anything special. What a speed control with BEC does is provide current for your Rx from the motor battery through the throttle channel. In that way smaller electrics do not have to carry a separate Rx battery. All Bec equipped speed controls now will reduce or shut off your throttle when the motor battery goes below a minimum votage to give you time to land under control.
John
John
Banned
Note: BEC's have a servo load rating in addition to the motor power (voltage and current) rating. Typically a 2 amp ESC's BEC can drive 2 and only 2 mini servos... or up to 3 "Naro" servos. a 5 amp ESC's BEC can drive 3 minis and MIGHT drive 4 Naros. The 8 to 20 amp 6 to 8 cell ESCs typically are rated for 3 "standard" servos.
READ you ESC's docs! Don't try to drive more servos load than the BEC section is rated for.
