Xmtr Analyser/Recorder/Active cable
Announcing a series of FREEWARE softwares to analyse a transmitter signal in real time on your PC.
Ideal to undesrtand your settings, mixers, a.s.o. Graphically displays your angles and forces. You can
view, adjust, move in real time the geometry of a servo and related links to the control surface just with your radio connected.
Good for beginners and for confirmed, with the cable and software, you start a new transmitter setting on the PC, not on your model.
Recording a simulated or a real flight is possible (max 15 minutes, all info from xmtr to rcvr is logged in a file); the playback will show the sticks moving at normal or reduced speed. The way to explain your last acrobatic figure or to refine the way of piloting!
Tested on Hitec Eclipse7, Laser4, Graupner MC20, MX22(all 12 channels visible in real time). Should fit almost all transmitters.
I developped also the active cable, based on a PIC microcontroller. It is quite simple, and harware cost for the total cable is under 10 Euros.
BTW, the cable works with the FMS flight simulator, even under WIN 2K or XP.
You will find the doc, softs, microcode and all info under NEWS/ARTICLE for (simple)PCM at:
[link]http://www.jdm-nivelles.be[/link]
There is an english version of the user's guide with plenty of screen shots in SPCMliste.htm
Happy flying,
Philippe
Happy flying,
Philippe
RE: Xmtr Analyser/Recorder/Active cable
Here the poster I used at a stand.I was demonstrating the Analyzer and record /replay functions with a transmitter connected to my PC.
Feel free to display the poster in your club for interested people. The site for download of the freewares is indicated on it.
Philippe.
Brussels Belgium.
Philippe.
Brussels Belgium.
Joystick trim, expo, travel
In the context of the (simple)PCM project, I will soon release a software that takes a joystick as input, shows all values, enables to make all adjustments like a transmitter (reverse, trim, separate travel limitations for both directions, exponential), and creates a digital signal as output.
Input: joystick 1 or 2 (game or usb).
Output: COM1 to 6 with a (simple)PCM data flow, ok for simulator like FMS, and my series of softwares (ref the (simple)PCM doc).
Control of individual channels by the mouse is also possible. This will generate (simple)PCM signals for other components of the project.
Typical setup in one PC: Joystick to game port or usb port, input to my joystick software, output to null modem cable with optional serial to usb converter, input again to simulator or other software, or to another component. You will be able to trim to fly perfectly horizontal, limit movements, put expo to get very small movements near center, a.s.o.
Philippe
Brussels Belgium
[link]http://www.jdm-nivelles.be[/link] See Article about (simple)PCM with all downloads.
Joystick.exe and Joystick.doc available in 'Article' about JOYSTICK at previous link. <==============
Philippe
Brussels Belgium
Win 940Euro plane - Air Show 2004
If you are in Belgium, north of France, or neighbour countries
The field is located 30km south of Brussels (near town Nivelles), close to E19 highway (Brussels-Paris)
Come and see us at our AIR SHOW 2004 Aug. 21 and 22
You can win a complete plane with full radio and tech equipement (value 940 Euros)
You will also get info about (simple)PCM project.
This is a pre-annoucement . Book the date in your agenda.
All info will be available soon on our website, with access map, a.s.o.
And a participation voucher that you will need to get your chace to win the prize (your presence at the show is mandatory to participate)
Feel free to print copy the flyer and show at your club.
Philippe
Brussels
Philippe
Brussels
SIM contest and demo's at Air Show 2004
There will be a SIMULATOR stand,
with RC to PC connection s demos,
and a simulator contest based on FMS, using the PIC cable.
This contest is separate from the main contest with 940 Euro prize.
See previous appends.
Philippe
Brussels Belgium
Philippe
Brussels Belgium
RE: SIM contest and demo's at Air Show 2004
RE: Belgium: Win 940 Euro plane + radio (in reply to phildc) Report This Post | (Post No. 2)
JDM Nivelles Air Show 2004
Participation voucher for the "PLANE" contest:
http://www.jdm-nivelles.be/images/bu...ticipation.jpg
The rules:
http://www.jdm-nivelles.be/images/reglement.jpg
and the access map:
http://www.jdm-nivelles.be/images/plan.jpg
You must handle it personaly at the Air show !
There is also a SIMU contest and many other activities (see flyer)
Philippe
The rules:
and the access map:
Philippe
The landscape and model used at the contest are available:
http://www.jdm-nivelles.be/fichiers/...velles_FMS.ZIP
Philippe
Brussels Belgium
Philippe
Brussels Belgium
New version of the ANALYSER software:
http://www.jdm-nivelles.be/fichiers/fms/Analyser2.exe
- You can input angle and length parms for a servo link
- You get the angle and force transmission curve
- Dynamic calculation and graphical display, under PC mouse control
- or real-time under transmitter control, with (simple)PCM cable
AND SOON AN "HELICO" REAL-TIME DISPLAY SOFT
Philippe
This software is part of:
it is a research project - look for 'Articles' about (simple)PCM at:
[link=http://www.jdm-nivelles.be]www.jdm-nivelles.be[/link]
The doc is also available in english!!
[link=http://www.jdm-nivelles.be/fichiers/fms/SPCMliste.htm]Downloads (doc and softs)[/link]
Philippe
Link for the HELICO real-time viewer: (beta-test version)
http://www.jdm-nivelles.be/fichiers/fms/Helico.exe
Philippe
brussels Belgium
Philippe
brussels Belgium
Last pointers:
http://www.jdm-nivelles.be/fichiers/fms/Analyser31.exe also supports a simple AUDIO cable for PPM
(MENU->INTERFACE->AUDIO, then do MONITOR).
PIC cable for FMS and my softs, see in:
My last softwares may be found at:
[link=http://users.skynet.be/phildc]users.skynet.be/phildc[/link]
and there is a topic (in french) about diagnostic techniques and tools for simulator cables, buddy boxes, viewing transmitter mixers, aso:
[link=http://forum.modelisme.com/t29141-techniques-et-outils-de-diagnostic.html]HERE[/link]
