who sells pcm 512 rx?
Can anyone direct me me to somplace where I can purchase a pcm 512 compatible receiver(new or used)? I have a 6npk that will is only compatible with the 512 pcm receiver.
Dave
Dave
AZ
RE: who sells pcm 512 rx?
ORIGINAL: d12294
Dave
Dave
Banned
Probably... you'd be better off upgrading to a newer radio system.
That OLD 512 PCM radio hasn't been made in a LONG time... and is probably considered collectable by some people. (like a 8088 based desktop PC.. it may still work... but... its about time to retire it.)
According to the manual though... you can use it n PPM mode with a 127DF RX... avoiding having to use the PCM RX that you can't find.
http://www.futabarc.com/manuals/6nfk-6npk-manual.pdf
Banned
OOOPS... I misread the manual...[&:]
There is a 6nFk and a 6nPk... they don'e switch select from PPM to PCM and back at all (neither radio... can [&:]) The graphic from the manual showing BOTH RX's as appropriate had me confused.
One manual... 2 different radios.
Sorry
Sorry
