Royal EVO Rudder to Aileron Mix
PA
I have a Multiplex Royal EVO 9 and am having problems setting up an Aileron mixer with Rudder Input, which I am trying to program to correct roll coupling when using the rudder for knife edge flight. I have read the manual and the tutorial and have all of my mixes working correctly except this one.
I have defined a mixer with Aileron (symetrical) and Rub-Tr (Asymetrical). Then set the mixer values to Aileron 100% and Rub-Tr -10% and +5%. Then assigned this Mixer to both Alerion Servo Channels.
BUT when I move the Rudder stick both of the aileron servos move in the SAME direction i.e. they act like flaps and/or spiolerons not like ailerons - one up and one down.
What am I doing wrong?
RE: Royal EVO Rudder to Aileron Mix
The rudder input to the mixer needs to be ordinary rudder with trim. Mpx designed it deliberately to behave differently depending upon whether the rudder trim is included or excluded.
H
H
