Throttle-Cut trouble with futaba 8UAP
Hi all,
I've been trying to setup the throttle cut in my second hand futaba 8UAP. I've been able to assign that to a switch and activate it. The problem is that the throttle cut only "works" on the upper side of the stick (Max) and to the upper side direcction.
The throttle servo is reversed, but i also have tryied in the normal mode, with the same result.
Thanks and sorry for my english.
Garikoitz
Garikoitz
RE: Throttle-Cut trouble with futaba 8UAP
Finaly solved!!!!
The problem was that the throttle stick was configured as reverse.
To put it in the normal mode it was necesary to access to an especial menu.
First you have to put off the radio, and then put on it with the two left buttons pressed. Then you have to select the throttle stick mode (it was reversed).
Thanks and sorry for my english,
Garikoitz
Garikoitz
