Bad glitches in OMP Edge
ok guys and gals I need a little help. I have a OMP gs540 with an os160 engine and futaba 9c radio, futaba 8ch rec, hi-tec 605's on all surfaces except the rudder. I put 5 wonderful flights on the plane and busted the hi-tec 605 I had on the rudder. I replaced the 605 with a hi-tec 5625 digital servo and went back to the field the next day. I always do a range check and when I did with the engine off I did not notice a hit or gitter, but when I range tested with the engine running ALL of the control surfaces would hit or gitter. I have tried everything I know to correct this. I have pulled all the servo's out of the plane and replaced the extensions, and checked many other things. Why now am I all of a sudden getting hits or gitters when I put a new digital servo on the tail? The plane may sit there and run for five minutes and not flinch, then all of a sudden it will go crazy. What can I do?
ok, the spell check did not work so please dont flame me
