Setting up twin throttle servos on a JR PCM9X
Old 05-23-2004, 01:03 PM
Dennismate
Default Setting up twin throttle servos on a JR PCM9X
Does anyone know how to set up separate throttle servos, using separate channels on a JR PCM9X. The instructions tell you how to slave one channel to a master but not how to take individual control of each engine. I would like to have a situation where I could flick a switch leaving one engine at, say, idle and be able to throttle up and down on the other.
Stuart
Old 05-26-2004, 10:24 PM
Chunkylad
Default RE: Setting up twin throttle servos on a JR PCM9X
Hi Stuart
Instead of utilising the master/mate scenario for your second throttle channel, try simply setting up the second throttle channel to the aux3 pot on the rhs of the TX, and using the flight mode switch (for example) to toggle a mix with the throttle channel.
Let me know if this works.
chunkylad
