Faraday Cage
Faraday Cage
I heard along the grape vine that wrapping your reciever in aluminium foil was a good thing in that it prevented interferece entering your reciever directly, i.e. you are installing your reciever in a faraday cage.
Does anyone have experience of this?
Would it not also prove benficial if you were to wrap your servo leads, I've got some long ones at the moment, in foil to prevent them picking up interference and feeding your reciever.
RE: Faraday Cage
yep thats a very good point, I had not thought of that. This noise might very well cancel out the suppresed interference.
I suppose you could get all fancy and cut a square block of foam with your reciver installed in it and then very carefully glue foil to the outer sides of the square block, mind you, you still need to electrically connect all 12 edges without any rubbing,
hmm is it really worth it?
RE: Faraday Cage
I am using a futaba R149DP, and I am not currently experiencing any interference, (it hasn't become airborne yet).
It is my first jet and I am just investigating ideas for improving the reliability of it , what with half a house morgage flying about up there.
I have installed a opto isolater in the radio system, from the recommendation of other jet jockeys who seem to be very concenered about interference and I heard about this method (reciever foil wrapping) at a jet meet.
AZ
RE: Faraday Cage
Many years ago the manufacturers of radios decided that putting a receiver in a aluminum case was not required either from a mechanical or electrical standpoint. Why do you think the fellows at your field know more than the maker just because they can fly a jet?
My Feedback: (19)
RE: Faraday Cage
If you think about it wrapping your reciever while leaving the antenna hang out of it is rediculous. any noise will be picked up by the antenna and transmitted directly, that's what it is supposed to do. shielded servo leads are another matter, having no external component to pick up noise I really dont know why someone isnt selling shielded servo lead extensions, Are they required no, but people buy lots of expensive stuff for giant airplanes and jets "hoping" it will make it better-more reliable.
AZ
RE: Faraday Cage
ORIGINAL: SMALLFLY-
What is truly needed for large powerful airplanes is a totally redundant system that provides two independant RF paths to the airplane in case one fails or is interferred with. Or as someone else suggested a spread spectrum system.
RE: Faraday Cage
Hi Dirtybird,
I did witness some kind of interference on a plane with an ignition engine, or at least it seemed that way to me. With engine stopped, control surfaces were steady. With engine on, they moved around spuriously. Some long servo leads were on the plane.
In this case, apart from a redundant system, what can be done?
AZ
RE: Faraday Cage
ORIGINAL: patternwannabee
Hi Dirtybird,
Hi Dirtybird,
AZ
RE: Faraday Cage
The trouble with shielding is you WILL most likely affect your antenna performance. Your receiver has been tuned without it. Adding all of that extra metal could detune it. And you could create reflections and dead spots.
