RD6000 throttle/rudder Question
Does anyone know if the RD6000 has the ability to switch from mode 1 to mode 2 via programming or does it need to be rewired?? Thanks for the help!
Tedd
Tedd
BC, CANADA
RE: RD6000 throttle/rudder Question
From what I've heard/read on here somewhere, there are a set of hidden service menus to let you make the switch... but you would also need to change/adjust gimbals. If you do a search, you should be able to pick up some info...or maybe call Airtronics and ask them how much it would be to make the switch for you...
Hope this helps.
Hope this helps.
Hello
To access service menu you have to turn all switches in 0 positions, flap & gear switch have to be up
then turn off radio
push fmode & end button and turn on radio
when LCD go blank
you have to push gear switch down.
on LCD you will see "SVC"
then go down to mode
change mode to mode2 or mode1
push "end button"
turn off radio
and turn on
now you have this mode what you selected
sorry for my english
then turn off radio
when LCD go blank
push "end button"
turn off radio
and turn on
