Torque requirement
CA
Torque requirement
I have always read posts on a certain airplane setup where people have ten different ideas about the torque requirements for all of the surfaces for the airplane
I would like to know how one would come up with the requirements to hold a certain surface for a certain airplane in place during flight. I know that the way you fly and what prop you use will change everything, but it would be a ballpark figure. I don't want to go out and buy a servo that won't do the job, and I don't want to spend way too much money either. Lots of people just say, "Buy $60 digital servos and then you won't have to worry." I don't want to do that. Thanks for all the help in advance.
RE: Torque requirement
Even on the same plane with the same engine, it depends on the type of FLYING you intend to do. If your setup on an 15 lbs Extra 300 is for precision IMAC pattern (control surfacethrows +/- 25 degrees), then a 60 oz nylon geared servo will do fine. However, if you intend to do 3D w/ the same plane (throws 50 degrees plus) you will need 100 oz metal geared servos.
Think about it, all else being equal, a 40 oz servo using a 1/2" servo arm exerts the same force on a control surface as a 80 oz servo using a 1" servo arm. The 1" servo arm produces much greater throw, of course, but the torque requirement is proportionally greater too.
Yeah, but the 3D plane isn't going very fast. Been wondering about this also. I think a lot of the 3D requirement is that there isn't as much airflow to center the control surfaces, to make matters worse the higher rate makes the error worse. The high torque servos have more torque near neutral as well, thus more predictable performance.
I really don't know just therorizing.
CA
I have thought about sport_pilot's idea as well. This was kind of what I was digging for, cause I didn't really have an answer and I wanted to see what responses I was going to get. Personally, I would try doing more 3D flying rather that winding out the motor and going as fast as I possibly could.
Sport_Pilot, what you say is true, but you also have to take into account a servo's ability to resist (note I didn't say "prevent") control surface flutter. Again, all else being equal, a servo capable of exerting high force on a control surface will better resist the onset a flutter, which is very common in 3D setups because of the extremely large control surfaces.
MS
Sport Pilot there's a lot more air rushing over those large 3d surfaces in slow manuvers than you would think. Take a hover for instance. The plane isn't moving, but the plane's weight in thrust is being pushed across those control surfaces. Other manuvers like a wall or elevator normally see the controls deflected greatly for brief periods. Okay, here's a simple test. Tie your 3d capable plane down and run the engine up to about half throttle. Then, unhook something like the elevator servo and try moving that surface linkage with your hand. It takes a lot of force to hold those big surfaces at an angle. If you really wanted to get technical, you could hook each control surface to a scale (one at a time) and measure the force needed to bring the surface to full throw at full throttle and consider that a ballpark minimum. I normally take this rule of thumb as my personal minimums, but you'll hear a lot of different opinions from others.
up to 40 sized plane: standards or servos with equivilant torque are just fine (I did go higher torque for my funtana, but I wanted to push it hard).
60 size: Standards would work in a pinch, but I like to stay above or around 65 oz.
giant scale: If I'm going to invest the money into a monster plane, I'm going with the highest torque/best responding servos I can buy.
My Feedback: (10)
I use a program called linkage design. It is actually a very advance spread sheet.
It take into account the speed of the plane and the size and deflection of the surface. It models all of the linkage parameters as well to take the non linearities into account.
http://members.cox.net/evdesign/page...ge_design.html
ORIGINAL: LuvBipes
[/quote]
It's commonly overlooked when calculating Force and or Torque that the rated TORQUE a given servo can deliver is a constant, regardless of the servo/control arm length.
[/quote]
Industry standard is to measure rated torque at one inch (that's why it's labelled "ounces/inch". Do not confuce force appliend to a control surface with rated torque. If you double the length of the servo arm, trust me that you will significantly reduce the FORCE applied to the control surface. It's simple leveraging/de-leveraging.
[/quote]
My Feedback: (31)
Josh's comment is accurate... There is no confusion. The comment was made to differentiate the two specifications and realized performance thereof.
FORCE and the servo rated TORQUE are one and the same at the 1" industry standard. FxD=T.
A servo rated at 100oz-in Torque is providing 100ozs FORCE with a 1" servo arm. A 2" servo arm will reduce the FORCE to 50ozs.. The same servo with a .5 servo arm will generate 200ozs Force.
So we can visualize how a shorter/longer arm will increase/reduce the SERVOS available Force while maintaining the servos rated TORQUE specification. As mentioned previously the servos TORQUE is constant and FORCE is a variable of the arm length in play. The FORCE introduced at the control arm directly influences the TORQUE a surface will realize. Again FxD=T.
100ozs Force introduced to a 1.5" control arm generates 150oz-in, 100x1.5=150oz-in TORQUE. Torque is defined as a twisting force.
My Feedback: (41)
ORIGINAL: LuvBipes
My Feedback: (41)
ORIGINAL: LuvBipes
BTW, I used a HT 635HB on my ailerons. 82 oz-inch at 6 volts. I thought they would be enough but they are not. They snapped off at the shaft right where the screw ends.
After doing your test, try out a standard $10 ounce servo on your smaller sport or trainer models. See how much force it takes to pull it out of neutral. Don't push the control surface, it will likely break! Much more force is required than to move the 3D elevator.
