twin throttle servo question
Old 06-21-2004, 08:39 PM
iwannafly
Default twin throttle servo question
Have a Futaba 9c radio and trying to figure out how to set up with dual servos on the throttles of a twin engine plane. Can't find anything in the manual that I can get a handle on. I'm also going to try to slave the steering servo to the rudder servo with ailerons on seperate channels. Am using a rcd seven channel rx. Any help with the procedures would sure be appreciated.
Old 06-21-2004, 08:51 PM
Rcpilot
My Feedback: (78)
Rcpilot's Avatar
Default RE: twin throttle servo question
Why not use a Y-harness for the 2 throttle servos and make sure the linkages are the same length?
Old 06-21-2004, 08:52 PM
speedy1379
Why not put the two on a Y harness?
Old 06-22-2004, 01:10 AM
smokingcrater
just mix aux1 (chan 7) to the throttle. make sure to select link and trim options. what you can also do at this point is mix your vr-d to your left throttle and vr-e to the right, giving you a certain percentage of individual control also.
Old 06-22-2004, 10:22 PM
iwannafly
Thanks for the input. I got it done.
