Changing Rx channel
Reply
Old 07-03-2004, 09:33 PM
SST
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Changing Rx channel
Got an older (but still narrow band) Futaba FP-R114H AM Rx on ch. 40 that I want to change to ch. 46. The guy at the LHS is afraid it won't work because I'm changing by more than 2 channels. I know I've heard you can't make wide changes in the TX, but I was unaware of any problems with the RX. Does anyone here know for sure? Thanks!
SST is offline
Old 07-03-2004, 09:43 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Changing Rx channel
Any crystal on channel 36-60 is interchangable in a 'high band' Futaba receiver. I've read that receivers "can be" finely tuned on a specific channel, but that's not done as part of standard production runs.
carrellh is offline
Old 07-03-2004, 09:50 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With your system being AM, many of us new guys may not have any experence there. I would say that if you are only changing the receiver, then change it and check your range before and after the change to make sure that you are still OK.
ORIGINAL: SST
Geistware is offline
Old 07-04-2004, 02:02 AM
mr.rc-cam
mr.rc-cam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The main point is to verify that the ground range test does not show a reduction in range. If things don't look good on the ground then an Rx tweak is needed.
mr.rc-cam is offline
