Connecting the 4 ail servos of GP Pitts
Reply
Old 07-04-2004, 08:05 PM
Marcos_Nieto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Connecting the 4 ail servos of GP Pitts
Hi guys.............I´m almost done with my first big plane project a GP Pitts 1/3 scale. This plane has four (4) operative ailerons and I plan to connect the aileron servos using two Y-harness; one for the two right ailerons connected to ch. 1 and the other for the two left ail. connected to ch.7 on my 9-C Futaba radio receiver. Is there any other configuration that will give more flexibility allowing trim of each ail. servos independently??
Any suggestion is welcome....
Marcos
Marcos_Nieto is offline
Old 07-04-2004, 08:46 PM
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Connecting the 4 ail servos of GP Pitts
I connected the top wing with a Y Left and Right.
Bottom wing with a Y left and right.
You dont want to many things coming down from the top wing.
I have found that it did not need any trimming assuming you take the time to set up each wing.
i think you will be hard pressed to seperate out each servo with 7 channels.
Just watch out for landings as Itl will grab you in the you know where if you go to slow !!!!
Panzlflyer is offline
Old 07-05-2004, 11:09 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can connect one wings ailerons using the flaperon set up plugging one aileron into channel 1 and the other into the channel called out in the book for that connection. Then connect the ailerons on the other wing to a channel for each servo and mix that channel to channel 1. (you can mix more than one channel to the same channel). You will have used 4 channels for the ailerons and each one can be trimmed independantly of the other while the system is not flying the airplane. This is a complex set up and may take a bit of working with the system to get it to do what you want without other problems.
dirtybird is offline
