Futaba 6EXA Tx& Hitec RD3600 Rx
My Feedback: (56)
AL
RE: Futaba 6EXA Tx& Hitec RD3600 Rx
Looks like Hitec makes several different kinds of 3600 Rx's. One for JR/Air, one for Hitec, and one for Futaba. I already have teh crystal for the channel I am on. I just hope it's on the same shift as the Tx.
Hitecs labeling and model numbers have always been confusing. The modulation shift and plug configuration is designated by the stock number I beleve. If the Rx is Negative shift it will be marked Hitec/Futaba on the label and if it is Positive shift it will be marked Airtronics/JR spelled out.
In the 2001 catalog the Shift selectable seven channel Supreme is shown as an RCD 3800
The eight channel Supreme in negative shift for Hitec/Futaba is pictured as the RCD 3500 stock number #23572
The catalog is vague but I beleive the positive shift version for JR/Airtronics is the RCD3600.
I suspect that your Futaba radio will not work with the RCD 3600 unless that 6EXA has a selctable shift feature.
John
John
