Antenna length
AZ
Antenna length
Just got a Dumas boat antenna. The Tower spec sheet on their web said it came with instructions. Bah. It does have a picture of how to install the thing but I could have figured that out by myself. I have already determined a better mounting than they show. My question is; should I shorten the length of the RX antenna by the length of the solid wire that is above the deck so that the total length of the antenna is 39 -40" overall. I am electronically challenged at any point beyond soldering and flipping the switches. Any help will be sincerely appreciated. TNX in advance.
AB, CANADA
RE: Antenna length
I am assuming that you are going to clip the antenna from the receiver short, and then connect the end to the inside connection of the boat antenna.
If that is the case, then the total length of everything (including the solid wire) from the receiver to the end of the antenna should be the same as the original antenna length (~ 39+ ").
In otherwords, yes it should be shortened by almost the length of the solid wire (left longer by the amount required to make your 2 connections)
Villy
(I am assuming that the boat deck is non-metallic)
Villy
RE: Antenna length
If the wire section on theboat is just that, a straight piece of wire, the above advice is correct. However, some antennas that have been put on boats (also on some planes) have a coil (this might look like a molded resistor) at the end of the wire nearest the receiver. This is just a choke that electically tricks the reciever into thinking the antenna is longer than it really is. If that is so, you only want about 3 or 4 inches of wire between the rigid antenna and the receiver.
CA
RE: Antenna length
Just got a Dumas boat antenna...
It is only coincidental that the typical length is nearly a perfect 1/4 wave for North American 72Mhz Rx's. Generally speaking, model R/C Rx do NOT follow the standard convention for 1/4 wave antenna lengths. Regardless of freq (35Mhz, 40Mhz, 50Mhz, 72Mhz, 75Mhz) the antenna lengths are shortened for our convenience and use compatible impedance matching techniques in the Rx's front end.
