resetting fut 9 cap
Reply
Old 07-14-2004, 09:06 PM
miamiflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default resetting fut 9 cap
Hello,
just bought a 9 cap ebay and it has lots of models set up. I am new to this
computer radio and want to start out fresh.
is there any way to delete the settings/models that the previous owner has made
and "reset" the radio to it's state it came when new?
I'm also running 7 servos on the new plane and would like to increase daily flight numers
without recharging at the field. which would be a good replacement upgrade
battery?
any help very much appreciated, thanks
pat
miamiflyer is offline
Old 07-14-2004, 09:10 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: resetting fut 9 cap
Yes, go to the parameter menu and select reset then press the dial to execute.
Geistware is offline
Old 07-14-2004, 09:50 PM
miamiflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks,
any battery suggestions for rx/tx?
Old 07-14-2004, 10:22 PM
HavinFun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In case you did'nt get the manual with the radio you can download it here;
http://www.futabarc.com/manuals/manual-9c.html
HavinFun is offline
Old 07-15-2004, 12:33 AM
smokingcrater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
for tx, just have a local battery place build you a pack for it, MUCH cheaper then buying a specific hobby one. I got a 1800 mah pack built locally at batteries plus for under $25. the 9c tends to eat batteries anyway, the stock pack isn't very useful.
smokingcrater is offline
Old 07-15-2004, 04:58 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The transmitter will consume about 300ma of current.
I wuld recommend at least a 1650maH NiMH pack.
This will give you 5.5 hours of on time.
THis is the pack I use.
AS far as the receiver, it depends on the kind of plane you have and the flying you do.
My plane burns 1.8 amps average.
So I need to have about 2400maH of capacity to safely fly an hour (6 flights)
You may not need this much.
ORIGINAL: miamiflyer
thanks,
Old 07-15-2004, 07:26 AM
miamiflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks guys,
it's going in a ustick60/saito100 model. some people at the field say they need to recharge once for the whole weekend
of flying. not sure what battery they used.
Old 07-15-2004, 09:53 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are using regular analog servos then I will say just use a 1400maH pack for all day flying.
You can also use two of the 600maH packs and be able to fly just about all day.
I would guess that 10 flights of 12 minutes each (2hours total) will consume 1000maH to 1200maH. (.5amp draw)
This is only a guess but you should see my rational!
thanks guys,
Old 07-19-2004, 08:18 PM
WRM
Radio Programming Futaba's 9CA by Harry Higley from RCM, it will show you how to program the 9CA.
WRM is offline
Old 07-19-2004, 09:06 PM
miamiflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
good one, thanks.
