8103 cut programming
RE: 8103 cut programming
Hi,
My 3810 has no throttle cut, just a mechanical trim for the throttle which I use to cut my engines. This works fine for me, but I spose if you want you could use one of the mixes and mix throttle to throttle, and have it set up on one of the mix switches. You will need to fiddle around a bit here.
Other radios have a digitial trim for the throttle, and have the throttle cut on the trainer switch, which I though was a pretty good system.
Stefan
Stefan
