How do I clean a coreless servo?
Got a coreless JR servo that is nervous. I always used to clean the pots on the older style but never had one of these apart, can it be cleaned to work correctly?
Paul
Paul
RE: How do I clean a coreless servo?
Will open one up for you and check it out.... cannot remember the guts of the 7005 off the top of my head.....
[8D]
[8D]
My Feedback: (31)
The procedure to clean a servo is identical for any type as they share the same components either digital/analog amp, cored/coreless motor the pots, gear-train and servo cases are all the same. Obviously I have exaggerated to some extent BUT all servos share the same basic design and components.
