Dual Conversion crystal PPM Rx
Reply
Old 07-23-2004, 07:40 PM
Rippah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual Conversion crystal PPM Rx
Will a Dual conversion crystal work in a PPM receiver?
Rippah is offline
Old 07-23-2004, 10:55 PM
Phil Cole
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dual Conversion crystal PPM Rx
If it's a dual conversion receiver.
PPM/PCM has nothing to do with dual/single conversion. Receivers can be had in all four combinations.
Phil Cole is offline
Old 07-24-2004, 01:49 AM
Rippah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats the problem, I dont know if it's dual or single. Its a FEIGAO 6ch mini 36mhz PPM. I tried it in PPM no joy then PCM using my Futuba 7UAPS. The only thing I can think of it must be the dual conversion crystal. SO I'm guessing if I swap it for a single I should be right?
Rippah is offline
Old 07-24-2004, 08:22 AM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PCM mode is only operational with like original equipment. This means only a Futaba PCM RX will work with a Futaba TX in the PCM mode. The code is proprietary and does not work with any other PCM equipment...
For the most part you'll have to use a crystal that meets the requirements of the specific RX in use, single/dual conversion is a secondary consideration but an absolute must. Crystals are not generally interchangeable from one manufacturer to the next. The crystal does not differentiate between PPM/PCM modulation modes, this true at of the TX and RX.
mglavin is offline
