Where do I find a schematic for the Futaba 4 ch TX?
Reply
Old 07-26-2004, 01:04 AM
GarbMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Where do I find a schematic for the Futaba 4 ch TX?
I guess this is about impossible to find. I, at least want to know the numbering of the pins. Can someone help me?
GarbMan is offline
Old 07-26-2004, 02:12 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Where do I find a schematic for the Futaba 4 ch TX?
Garman, what do you need the info for ?
rajul is offline
Old 07-26-2004, 03:04 AM
GarbMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm trying to identify the pinout of the main chip on the circuit board. I have learn some from this post:
http://www.rcuniverse.com/forum/4_to...1958892/tm.htm
But my chip is different then the ones in the links suggested by Olivier.
GarbMan is offline
Old 07-26-2004, 01:18 PM
ZAGNUT
ZAGNUT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you can read your chips part number then look up the maufacturers data sheet. all info should be there.
dave
ZAGNUT is offline
Old 07-26-2004, 01:46 PM
mr.rc-cam
mr.rc-cam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the main chip a NE5044?
mr.rc-cam is offline
Old 07-27-2004, 01:27 PM
GarbMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, the chip is not the NE5004. It is a 32 pin chip found in the Futaba Skysport 4 Channel. It has the Futaba name on the chip and has two sets of numbers on it. FP6335 and 310 143100.
GarbMan is offline
Old 07-27-2004, 01:46 PM
mr.rc-cam
mr.rc-cam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For native pinout's, download the Mitsubishi 4513/4514 4-bit Micro data sheet. I think you may find that it is the MCU used in your Tx (it is used in other Futaba models). This certainly won't tell you how Futaba configured it, but it will at least get you pointed in the right direction (Dig I/O, A/D inputs, etc.). BTW, what is the FCC number printed on your Tx?
Old 07-27-2004, 03:53 PM
ZAGNUT
ZAGNUT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here's the [link=http://www.renesas.com/avs/resource/japan/eng/pdf/mpumcu/e4513g.pdf]DATA SHEET[/link] for the mitsubishi part that mr.rc-cam mentioned. the 32 pin variety has only 4 analog inputs so i doubt that any more proportional channels could be added...
i did find a [link=http://home.planet.nl/~toore015/RC.htm#_Toc490877710]LINK[/link] though that shows how to add a switched fifth channel...looks easy too
dave
ZAGNUT is offline
Old 07-27-2004, 04:10 PM
ZAGNUT
ZAGNUT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
another [link=http://staffi.lboro.ac.uk/~copal/pal/play/radio_control/futaba.htm]LINK[/link] that deals with adding a 7th channel to the skysport6. good detail about the pin-out of the chip, might be of some help on the skysport4
dave
ZAGNUT is offline
Old 07-28-2004, 12:59 AM
GarbMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I added a 5th Channel to the Skysport 4. It works like a dream. Here's the link: http://home.planet.nl/~toore015/RC.htm
It's great for sims too.
Thanks guys for the info. Well, I've goning surfing for the info at the links you gave.
GarbMan is offline
Old 08-02-2004, 12:35 AM
GarbMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still haven't identified channel 6 and 7. It may be above my knowledge to add these two. The added channels would be good for the sims. I have been informed that by FCC law it is illegal to use a modified radio in the field. This is just for sims.
GarbMan is offline
