Futaba 9z mix problem
Reply
Old 07-28-2004, 08:37 AM
Jetkopter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba 9z mix problem
I have a problem with a mix I created in for my
Turbine jet model. I am running a crow setup and am having a problem
with the
aileron servos going beyond the atvs I set. My set up is as follows. I
am using the
normal airplane setup, not the glider program. I have mixed channel 1
aileron
Left aileron to aux2 right aileron with the trim enabled. The atvs are
set
for each channel and the work perfect. Next I created a mix with the
flap
channel. The two flaps are on a Y harness. The flaps being the master
and left
aileron being the slave. Then I created a mix with flaps as master and
aux 2 right
aileron as slave. Both mixes have an offset and the rate set and give
the
proper operation. The problem I am having is when the mix is activated
the aileron
servos do not obey the atvs I have set and bind the servos. Do I need
to go
about this a different way? Or is it just a simple problem with linking
or a
mixed \unmixed issue? Any help would be greatly appreciated
Don DeSandre
Jetkopter is offline
Old 07-28-2004, 09:34 AM
RightThrust
RightThrust's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba 9z mix problem
Have you tried selecting "Lim" instead of the default "Nor" mode in the ATV menu?
-Kelly Gerber
RightThrust is offline
Old 07-28-2004, 03:09 PM
Jetkopter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No I have not, but I will try that tonite. Thanks
Old 07-28-2004, 10:20 PM
Jetkopter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tried the limit mode and its the same problem. Any other ideas guys?
