Icom IC-R5 Frequency Scanner Help!
Reply
Old 08-01-2004, 11:59 AM
Byronman
My Feedback: (55)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Icom IC-R5 Frequency Scanner Help!
Can anyone give me some help with setting up my scanner. Have had it almost a year and haven't used it because I can't figure out to set it up to be used for scanning all the AMA Aircraft frequencies. You have to be a darn Harvard graduate to understand the directions they have provided with the radio! I'm trying to do two things:
1. Program into memory each radio frequency from channel 11 (72.01 through channel 60, 72.99)
2. Would like to be able to scan from frequency 72.01 through 72.99 only (this would allow me to see what channels are in use against the pins on the frequency board at the field).
If you can help, please email me directly at: bjasper@corp-ben-adm.com
Thanks!
Byronman is offline
