servo extension wiring
Reply
Old 08-02-2004, 10:58 AM
rlarkin70
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo extension wiring
hi all-
just wondering if there is any harm in using servo extensions using not-braided (ie. solid) 22AWG wire. I have a supply of this stuff (twisted pair telecom cable) and was going to just cut and solder the extension in place. I know braided wire is a more efficient conductor, but will there be a noticeable difference in a 20-24" extension?
thanks!
-ron
rlarkin70 is offline
Old 08-02-2004, 11:53 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: servo extension wiring
ORIGINAL: rlarkin70
hi all-
thanks!
-ron
I would NOT use solid wire. The mult-stranded wire is much more flexible. The solid is more inclined to break after being bent several times. The only time you would want to use solid is if you know it will not move at all. That's not likely to happen inside a model airplane pulling 10 g's. The stuff is cheap so buy the correct wire. Good question though.
PS: Welcome to RCU if you're new here.
JoeAirPort is offline
Old 08-03-2004, 12:03 AM
rlarkin70
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you're right, that makes sense. i was coming at it more from a connection point-of-view, ie. is the signal and voltage reaching the servo going to be affected. of course, it matters a lot more if NO signal is reaching the servo! ie. a broken wire turns a fun day into a "what the...?" day. so stranded it is...i appreciate the input.
and thanks, yes, I am new to RCU. =) I am enjoying the forum and the responses, and hopefully I can give back as well.
-ron
Old 08-05-2004, 07:42 AM
JL1
My Feedback: (93)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with JoeAirPort, solid wire is very susceptible to breakage from vibration. It is particularly prone to breakage where the insulation is stripped. If there is even the slightest "nick" or compression where your strippers cut the insulation it will break at a future date.
JL1 is offline
Old 08-05-2004, 06:50 PM
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And then, is it better to crimp or solder?
voyager_663rd is offline
Old 08-05-2004, 07:25 PM
mstroh3961
mstroh3961's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SOLDER!
mstroh3961 is offline
mstroh3961
mstroh3961's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
double post
Old 08-05-2004, 07:45 PM
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heard you the first time Mark. :-)
Old 08-05-2004, 08:10 PM
mstroh3961
mstroh3961's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DOH!
My apologies for the double post! I swear I only hit the button once!
