JR 10X and Trace Rate?
Reply
Old 08-02-2004, 08:47 PM
flyinrazrback
My Feedback: (69)
flyinrazrback's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR 10X and Trace Rate?
I understand that once the throws are setup equal, you can use the trace rate to increase the throw. I am running the elevator channel and aux 3 for the second servo. (setup using
the D/ELE function in the wing function #22)
When I trim up or down with the trim tab, both servos move, but when I adjust (or turn up) the trace rate on the elevator, it only affects one of them and not the other. I havent tried the ailerons to see if they do the same, but right now I am trying to figure out the ailerons. Also, on the 10X is it best to set the Travel of say the elevators to 150% up and down to get the best resolution, or leave it at 100%?
flyinrazrback is offline
Old 08-03-2004, 07:05 AM
Imac Kiwi
Imac Kiwi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR 10X and Trace Rate?
1) Are you using the pre programed dual elevator mix ?
2) 150% travel will give you improved resolution.
Imac Kiwi is offline
Old 08-03-2004, 09:13 AM
flyinrazrback
My Feedback: (69)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using the dual elevator setup by going into the wing fucntion #22 and selecting D/ELE and activating it. Thats the only mix I have. works fine that way and trim works automatically, but trace rate does not.
