Futaba 6EXA
Reply
Old 08-05-2004, 09:23 AM
jacs
jacs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba 6EXA
Hi, got a new transmitter only a month old and in the beginning I had 25m when the antenna wasn't out and today it's only 20-30cm. I have changed to another reciver same result, changed the crystals same result and tried with a different transmitter with my reciver and are back to 25m range.
Is this standard Futaba quality or what. My old Hitec transmitter is in better shape than this one.
jacs is offline
Old 08-05-2004, 09:54 AM
Primodus
My Feedback: (56)
Primodus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba 6EXA
I have this radio and it works fine for me. I cant understand how your range can be so severely diminished. When you changed Rx's did you use a different band? What channels are you using on the Tx, or crystals?
Primodus is offline
Old 08-05-2004, 10:23 AM
jacs
jacs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have channel 66 on the 35MHz band here in Sweden and changed to channel 62 on both with no success. If I use my Hitec transmitter it works correct on channel 66.
jacs is offline
Old 08-05-2004, 11:54 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used the 6EXA for a year with zero problems. Many many hours of flying on it. It's a great TX.
Joe
JoeAirPort is offline
Old 08-05-2004, 12:40 PM
jacs
jacs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think so too that it's fine but after this malfunction I'm not satisfied. Al my friend said that I should buy a Futaba rater then Hitec but after this I'm not convinced that Futaba is better than Hitec.
jacs is offline
Old 08-05-2004, 12:54 PM
Primodus
My Feedback: (56)
Primodus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could be a lemon of a radio, but that's a warranty issue for Futaba. I noticed your cross post in the Futaba support forum, be sure you let them know what frequencies and channels your using. Good Luck.[8D]
Primodus is offline
Old 08-07-2004, 03:54 AM
jacs
jacs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally the service guy called me and after a little time, he told me that the regulator was gone. Because I had tried to charge it via the chargejack (only 20sec) and not like I used to (pulled out the battery and charge it that way).
jacs is offline
Old 08-08-2004, 01:27 PM
dabigboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ehhhmm, if you're not supposed to charge it through the CHARGE jack, what's the CHARGE jack for..........? :P Concerns me a bit, as I always use the charge jack and am considering a new radio some time.
-Matt Bailey
dabigboy is offline
Old 08-08-2004, 03:19 PM
jacs
jacs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know, I found a jack that fitted because my old Hitec jack didn't and pluged that in my Supernova on manual and 0.1A charge. No information about polarity error, then only thing was that the voltage when up and down (not exceeding 11.8V) so I stopped it and pulled the batterypack out of the transmitter and charged it that way instead. This broke the regulator but I have sent my transmitter today and hopefully I will get a small report on the malfunction when I get it back.
jacs is offline
