Sanwa RD 6000 buddy box cable!
BC, CANADA
Its compatible with RD6000 series, VG400, VG600, Radiant or Vanguard PPM. It is NOT compatible with Infinity 600 or Quasar.
Hope this helps!
Hope this helps!
BC, CANADA
From what I've seen, each manufacturer uses a different cable... also, you'd have to know which pin is carrying which signal on which transmitter and try to figure out if the two were compatible... it MIGHT be possible, but I wouldn't want to try it!.. Its probably safer to just say that each manufacturer is compatible only with it's own equipment!
