Futaba Throttle Channel Not Working
Reply
Old 08-12-2004, 07:08 PM
davemartin88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba Throttle Channel Not Working
Trying to use my Futaba 9CH TX with a 4 channel GWS narrow band receiver on my Graupner Terry. Has a speed 400 motor from Graupner with a built in ESC. Can't get this radio combination to control the throttle, other channels (airleron and elevator) work fine but no control of the throttle, have tried reversing but no good? If I move the control cable from the ESC to channel 4 (rudder), when I move the rudder stick, the motor control works as expected (although all the control is on the right side of the stick). Can't imagine what this would be but probably something simple. If I replace the TX/RX with JR components, it works fine as well.
Doesn't seem like a problem with the ESC unless it is a compatibility issue with the Futaba but not sure why it works on the rudder channel.
Thanks in advance.
davemartin88 is offline
Old 08-13-2004, 07:33 AM
Flypaper 2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba Throttle Channel Not Working
Dave:
Try, reverse throttle channel, then lower throttle end point to 150%. The end point may not be going low enough to arm the ESC. Once you get it to work, the throttle engagement may be to high on the stick, so move the end point up till the motor engages just above lower stick postion. Hope this helps.
PS Do your settup without the prop on, for safety purposes [ found out the hard way][]
Flypaper 2 is offline
Old 08-13-2004, 05:12 PM
davemartin88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Channel was already reversed, tried upping the end point to 140% (max) and no help, good thought though. I used one of the programmable mixes and moved the motor connection to channel 4, then did a 100% mix and the motor operates as it should. No idea why I would have to do this but will keep trying, thanks again.
Old 08-13-2004, 05:45 PM
TTARK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave what club do you fly at??
Terry
TTARK is offline
Old 08-13-2004, 06:37 PM
davemartin88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LCAA-- at Banshee Reeks Park-- I live 10 minutes from there in Leesburg, you're field is down in Arcola, right?
Old 08-13-2004, 06:58 PM
TTARK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right, good field with good people. We have a pattern contest on the 21st of this month and several events coming up. check out www.1nvrc.com for the club calender. We also have an UGLY STICK fun fly coming up in Oct You have my personal invitation to join us
Terry
TTARK is offline
Old 08-14-2004, 05:00 AM
Freakazoid
Freakazoid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey, did you check your throttle hold switch yet? As I remember, all computer futubas have throttle hold in theire software. I use mine to safety my heli, so perhaps you accedently activated yours.
Also, did you wait for the ESC to activate? Most need 5 secs of nothing time to calibrate the 0% throttle point.
Freakazoid is offline
Old 08-14-2004, 07:05 AM
davemartin88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, doublechecked the throttle hold-- I use it on my helicopters too- but it was okay. I gave it plenty of time to reset and interestingly, as soon as I mapped the rudder to the throttle, when you plug in the battery, you get the beep to signify it's ready within a couple of seconds. Very strange, at least I can give it a try but forecast calling for big rains here in Virginia today as the remnants of Charley comes up the coast.
