futaba 9c airbrake mix
Reply
Old 08-12-2004, 08:11 PM
flyingchicken
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default futaba 9c airbrake mix
any one if its possibe to mix airbrake (im using as flaps on a patriot instead off flapprons cause im using differential ailerons) with landing gear and also to have it offset on a different switch so i can add a little off flap on take off??????
flyingchicken is offline
Old 08-13-2004, 10:50 AM
Krysta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: futaba 9c airbrake mix
Hi flyingchicken,
I am not sure if this is exactly what you want, but you might want to try the following. You will of course need to adjust the rates as desired.
Go into Aux channel and put your channel 5 gear switch on the switch that you want it. Then go into the advanced menu activate Airbrake. You will of course have Ail Diff activated also. Now do a Pmix from Offset to gear with link Off, and put this on Switch C in the down position, on the next page you will want to set your percentages to whatever is correct for your model.
This will give you normal retracts on the switch you chose, but still give you mixed gear action with your Airbrake switch.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krystaustomer Sraian
Krysta is offline
