Charging question on Futaba 7UAF
Reply
Old 08-14-2004, 07:41 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Charging question on Futaba 7UAF
Got a question about chargin a standard battery pack on an "older" Futaba 7 channel UAF.
Where the charge plug inserts into the back of the radio, I do not get a good connection. The charge light will not always go on. If I rotate the charge plug it may or may not light up, or if I put slight pressure (sideways)on the plug it will charge.
From this, I can tell it is not getting a good connection. Anyone else have this problem ? Should I send it in to Futaba to replace the connection ? The charge plug will work with another Futaba radio I have, so I know it is not a faulty charge jack.
Also when charging, I leave the radio in a transmitter case and run the charge cord into a hole I made into the case so it will plug into the radio.
Thanks for the advice
Cary
mustangman177 is offline
Old 08-14-2004, 06:45 PM
Don M.
Don M.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Charging question on Futaba 7UAF
I would have it fixed if it was mine !!
Don M. is offline
