opposite servos
opposite servos
Have heard that some servos by different manufactures move in the opposite direction.I use futaba and hitec and would like to know what servos move opposite of these. Thanks for any help with this.
Lonnie
Lonnie
NE
RE: opposite servos
I don't have an answer to your question, but reversing a servo is very easy if you can handle a soldering iron. Reverse the two outside lines on the pot and reverse the two lines on the motor.
My Feedback: (13)
RE: opposite servos
Sorry but I gotta expand on the original question a little bit if I may... Why would it ever matter? You would NEVER want to mix servos of different manufacturers or even different models from the SAME manufacturer on the same control surface so why does it really matter?
I really don't "get" the question. Can you give us some context here? I'm sure we could regirgitate to you what turns clockwise by default and what turns counter-clockwise by default but the smart thing to do is to first discourage you from doing something you should never do regardless of servo direction.
RE: opposite servos
I was thinking of not having to use a servo reverser. and i mix servos all the time. such as hitec futaba hobbico jr and have had no problems. IT was just an idea. and is there such servos?
Lonnie Thanks for your help
My Feedback: (13)
RE: opposite servos
On the same CONTROL SURFACE? Re-read what I said please.
ORIGINAL: crownvic
RE: opposite servos
Thanks thats all i wanted to know. so if i use a futaba on one flap and hitec on the other I dont need a servo reverser or on the elevator.
