Futaba receiver model numbers?
Reply
Old 08-24-2004, 04:52 PM
Jimmbbo
Jimmbbo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba receiver model numbers?
Need help understanding the numbering system for Futaba receivers... I understand that the last number represents the channels, and that D indicates Dual Conversion, but am confused about the 12X, 13X, 14X designations.. e.g.; what is the difference between R128, R138 and R148 8 channel receivers? Are there any other significant model number issues?
TIA!!
Jim
Jimmbbo is offline
Old 08-24-2004, 07:21 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba receiver model numbers?
Well first, I am not an expert.
I can tell you what I know.
R is for receiver.
12?, 13?, 14? are model package types. The electronics inside may be different as well
??7, ??8, ??9 is the number of channels
D as I understand is for dual conversion.
P for PCM and F for PPM
R149DP is a reciever, package type 14, 9 channel, dual conversion, PCM modulation.
ORIGINAL: Jimmbbo
TIA!!
Jim
Geistware is offline
Old 08-24-2004, 10:11 PM
Jimmbbo
Jimmbbo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Geistware
R is for receiver.
ORIGINAL: Jimmbbo
TIA!!
Jim
Geistware,
Thanks for the reply
I presume the higher the number (12, 13, 14) the later the version?? Any advantages of one model over another?
Any compatibility issues with either a 9AC or 6YG transmitter?
TIA
Jim
Jimmbbo is offline
Old 08-25-2004, 05:48 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is not necessarily true.
If I remember correctly, the 12 came out with the 512 PCM units.
Following that the 14 were released with a smaller housing and for the 1024 PCM units.
The 13 is new at least for the PCM version (1024) and I have not seen an FM version.
Remember, while each unit comes in a PCM version, only the 12, and 14 come in a FM version. I have at least one of each, and they all work just great.
ORIGINAL: Jimmbbo
Geistware,
TIA
Jim
Old 08-25-2004, 05:54 AM
iflyj3
My Feedback: (7)
iflyj3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Geistware
Now, I am really confused. I have R129DP which is a 1024 unit. What was the number for the 512 unit?
iflyj3 is offline
Old 08-25-2004, 07:38 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are correct.
THE 124, 127, 128 DP are all PCM that are 512.
I do stand corrected.
http://www.futaba-rc.com/radioaccys/old-receivers.html
ORIGINAL: iflyj3
ORIGINAL: Geistware
Old 08-27-2004, 10:57 AM
Krysta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi iflyj3,
On Futaba receivers, the first number denotes that it is either a Synthesized (3) receiver, or a crystaled (1) receiver. The second number denotes the model and the third number denotes the number of channels. The D of course means Dual Conversion, the P or F means PCM or FM.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Krysta is offline
