anything wrong with buying a used transmitter?
Reply
Old 08-27-2004, 08:26 AM
rob6894
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default anything wrong with buying a used transmitter?
I just bought a used transmitter for my plane use the guy that owned it. Told me it is in excellent condition. Is their anything I should do to test the TX besides range testing before I use it?
Best,
Robert
rob6894 is offline
Old 08-27-2004, 02:07 PM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: anything wrong with buying a used transmitter?
You will never know for sure how the previous owner treated it.
dirtybird is offline
Old 08-27-2004, 02:56 PM
canavanbob
My Feedback: (20)
canavanbob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dirtybird,
You could say the same thing about a new transmitter and with a new transmitter you have to worry about infant mortality.
canavanbob is offline
Old 08-27-2004, 03:00 PM
joeb102072
My Feedback: (9)
joeb102072's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depending on what type of TX it is there are some options. My brother and I bought 2 Futaba 9 CAPs used and we sent them to Futaba Tech services. They bench tested them and did all the appropriate diagnostic shecks to make sure they are in working order and then shipped them back to us. $ 65.00 not a bad piece of insurance.
joeb102072 is offline
Old 08-27-2004, 03:28 PM
rob6894
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
canavanbob, who I just purchased this from, offered to send it in to manufacturer to get checked out and install the latest software update and then have the manufacturer send it my way as long as it was ok with the manufacture. So I am now feeling good and canavanbob seems like a good guy.
Best,
Rob
rob6894 is offline
Old 08-27-2004, 08:56 PM
GRANT ED
GRANT ED's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can't get a much better deal than that.
GRANT ED is offline
Old 08-28-2004, 10:47 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: canavanbob
Dirtybird,
Yes but then you could just turn on a new transmitter and run it for awhile to get over the infant mortality
Old 08-28-2004, 09:39 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Buying a used transmitter is like buying a used anything. Probably fine, but maybe not.
You pays your money and you takes your chances!!
aeajr is offline
Old 08-29-2004, 12:50 PM
laryboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nothing wrong with buying used.......signed larry boy....used car salesman.
laryboy is offline
Old 08-29-2004, 03:30 PM
olivier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
The classical "surprise" when buying a second hand transmitter is that the battery isn't lasting very long. Typical for Nicad-batteries that are "worn-out" after 4 or 5 years of service. And yes, probably some will say their battery is lasting now for more than x years without problem. Just consider them lucky.
Eventually check any moving-wires soldered to the potmeters of the sticks (typical for Futaba, but not really a typical failure).
Eventually also check for "black-wire desease" on the black wire of the battery pack. That's a more common problem : corrosion due to whatever electro-chemical magic on the cupper wires.
Good luck, happy flights,
Olivier
olivier is offline
Old 08-29-2004, 09:09 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My 9C was purchased used and has worked great!
Geistware is offline
Old 08-30-2004, 01:41 PM
F-16WpnsTech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While we're on the subject....I bought my Futaba 6Xas used. I have no doubt the guy I bought it from treated it like royalty. Anyway, where can I send it to have it checked out for that "insurance"?? Thanks.
F-16WpnsTech is offline
Old 08-30-2004, 02:21 PM
Highflight
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: F-16WpnsTech
You could send it back to the Futaba service center, but if it's out of warranty, I would better suggest Radio South.
http://www.radiosouthrc.com/
Highflight
Highflight is offline
Old 08-30-2004, 03:09 PM
ZAGNUT
ZAGNUT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
something not visible is a damaged output transistor in the rf deck. happens when the transmitter is powered up for long periods with the antenna removed or collapsed, some radios are more prone to failure than others. but if the radio is being sent in for a check-up they would no doubt find this and fix it.
dave
ZAGNUT is offline
Old 09-04-2004, 10:46 PM
bullet65
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well if canavanbob is going to all that much trouble then it probably will be ok.i think when you have it checked they also send back a printout on what they found.i bought a futaba 8 channel last year used as i was new to rc and loved the thing.but then as i became more aware of things you should do,learning in other words,i was going to send it in at the end of flying season then i crashed my se due to tx failure.leason is if you buy 2nd hand,and i would do again,send it in to be checked.
bullet65 is offline
Old 09-05-2004, 11:05 PM
WhtBronco
WhtBronco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a good deal to me. If it's sent in for a check up it should be fine. I dropped my JR662 before I had ever flown it. So I sent it to Horizon to be checked out. For just under $20 they sent it back to me saying it was just fine. Maybe a waste of money, but it made me feel better about using it in my new plane.
FWIW, I bought the radio second hand here on RCU. The Tx had been used primarily for trainer cord service. The rest of the system had never been unpacked. It has worked great for just over a year now. Course with my new 8103 the 662 will now be retired.
WhtBronco is offline
