Hitec Flash 5 Memory Battery
My Feedback: (8)
NM
Hello,
Does anyone know where to get a replacement battery for the internal memory on a Hitec Flash 5 radio. I was given the radio because it would not hold onto any adjustments once the radio was turned off. The guy who gave it to me had open up the case and there appeared to be a "waffle" type battery in a round holder. I am trying to see if this can be replaced.
Thank you,
Jerry
Thank you,
Jerry
MI
RE: Hitec Flash 5 Memory Battery
The Flash 5 doesn't autosave. You have to go to the save menu and select save or the settings will be lost when the power is turned off. The Flash 5X does autosave, that was one of the improvements. I have two flash 5 transmitters that I seldom use. When I tried to use them this year I had the same problem until I read the manuals again.
Maybe I will have problems in the future with my old Focus 4 when I can't access it model memories (oops it doesn't have any). I've become too spoiled by my Eclipse and Flash 5X.
