TX Antenna Broken
Reply
Old 09-06-2004, 07:39 AM
ZM2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default TX Antenna Broken
I have a Futaba Skysport 4 radio. The top segment of the transmitter antenna came off. Its a solid rod, about 6 inches long with a small hole at the bottom. Any good idea how to fix it again?
Thanks.
-ZM
ZM2000 is offline
Old 09-06-2004, 07:42 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TX Antenna Broken
That antennae screws out, just get another one and put it in
Geistware is offline
Old 09-06-2004, 07:47 AM
ZM2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You mean replace the whole antenna with new one? Easy. Question was if the existing one can be fixed.
-ZM
ZM2000 is offline
Old 09-06-2004, 12:04 PM
quint-rcu
My Feedback: (24)
quint-rcu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Price a replacement antenna, compare it to the cost of fuel, or some of your other acessories and go buy a new one. Repairs are possible, but not recomended.
quint
quint-rcu is offline
Old 09-06-2004, 12:35 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ZM2000
-ZM
Nope, it cannot be effectively repaired without causing yourself agrivation every time you want to extend it. As suggested above replace it they are cheap.
John
JohnBuckner is offline
Old 09-06-2004, 01:04 PM
ZAGNUT
ZAGNUT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
didn't anybody bother to look where ZM is posting from?? there still are places in the world where finding the simplest things can be a major lesson in frustration.
ZM the quickest, most reliable fix would be to insert it about 1 cm into the next segment and solder it in place. BTW i gave up on collapsible antennas years ago. i now use a music wire whip soldered to a threaded adapter made from a brass screw.
dave
ZAGNUT is offline
Old 09-06-2004, 02:09 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Solid antenna's are actually better because you don't have to worry about contact resistance between segments. Lots of people have had problems when they oil up their antenna thinking to let them slide better, only to find out it kills their range checks because the oil is acting as an insulator between the segments.
Lynx is offline
Old 09-06-2004, 03:37 PM
JohnBuckner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are absolutely correct Dave and no I did not catch the location. In this case of course soldering would be the only practical solution of course if you can get the section inserted into the next section. Not very convienent at times but would keep you flying reliably.
Lynx's observation about the oil from you hands is a common problem also even with a healthy antenna. For this reason on my most used Tx's I do periodicaly clean the antenna with a clean rag soaked in some alcohol and this does wonders in keeping the segments sliding easily along with maintaining electrical continuity.
John
Old 09-06-2004, 04:28 PM
buchtes
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JohnBuckner
Super Contributor
be a pal and send him a new one
buchtes is offline
Old 09-07-2004, 12:34 AM
ZM2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot folks, its always interesting to see how others do it.
ZAGNUT what is the guage and length of music wire you are using.
-ZM
ZM2000 is offline
Old 09-07-2004, 08:48 AM
ZAGNUT
ZAGNUT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i use 2mm wire the same length as the original antenna and add a plastic bead to the tip. this gives the radio the same balance and feel as the telescoping antenna.
dave
ZAGNUT is offline
