Reciver Antenna Cut
Old 09-28-2004, 08:00 PM
charleyrc
Default Reciver Antenna Cut
I was removing a known good receiver from an airplane and accidentally cut approx 3 inches off the end. Range check on the ground seem fine but I am just not sure. Can I re-attach (solder) the broken end back on and keep going or would this be suicide? This is a hi-tech 7 ch standard receiver. The Pilot I have glued in the cockpit doesn't have an opinion. I think he will fly anything!! Any thoughts would be appreciated.
Old 09-28-2004, 08:35 PM
aeajr
aeajr's Avatar
Default RE: Reciver Antenna Cut
No problem solderinng the wire back on. Make sure you cover it with shrinkwrap or tape to be sure it does not short on anything.
Old 09-28-2004, 08:50 PM
BBW Walt
BBW Walt's Avatar
Have you considered another pilot
Old 09-28-2004, 09:01 PM
charleyrc
I didn't expect such a quick reply. Thanks for the advice.
Old 09-29-2004, 11:32 AM
dirtybird
As you proved, three inches does not make that much difference. Solder it back on if you wish but I would be tempted to just forget it
