hitec pcm to futaba pcm
Reply
Old 09-22-2004, 09:24 PM
slammed2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default hitec pcm to futaba pcm
I am curious i like hitecs equipment but i have a futaba pcm transmitter. I know that hitec works with futaba but can i use a pcm hitec reciever with my futaba pcm reciever in pcm mode.
thanks for the replys and happy flying to all,
slammed
slammed2000 is offline
Old 09-22-2004, 10:19 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: hitec pcm to futaba pcm
Sorry no, there is no interbrand compatablility with PCM systems. Also both Hitec and Futaba have old and new PCM systems that are not even compatable with the same brand.
John
JohnBuckner is offline
Old 09-23-2004, 02:42 PM
hilleyja
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: slammed2000
slammed
Actually, you have a Futaba TX that can either transmit on a Futaba-unique PCM modulation or general FM modulation. The general FM modulation is compatible with all FM receivers that accept negative shift signals. (Futaba, Hitec, Hobbico, GWS, etc)
As the previous poster indicated, there is no compatibility between different brand PCMs. Hitec's older PCM RXs are also not compatible with their new PCM option on the Eclipse 7. Futaba's older PCM RXs are also not compatible with the newer TXs (512 vs 1024 sampling) I'm not sure if Futaba 9Z's PCM RX is compatible with the Futaba 9C.
hilleyja is offline
