Will the Futaba 7C Transmitter Work with a JR R700 Mini PPM 7Ch Rx?
I would like to hear your opinions on the two makes working together and if I would encounter any problems or if it would work at all. Can you mix and match manufacturers, or do you have to stay with the same manufacturers equipment?
Banned
RE: Will the Futaba 7C Transmitter Work with a JR R700 Mini PPM 7Ch Rx?
Futaba = Negative shift
JR = positive shift
they will not work together.
Hitec makes rx's that you can get both ways.
JR = positive shift
Ok, I have just bought my first electric Heli and I will be using Futaba GY401 gyro, 1x Hitec HS-50, 3x HS-56B micros servos and was looking to buy the bestpossible micro rx, I was told JR R700 Mini PPM 7Ch Rx was the best one to go for so does anyone have any suggestions as to a suitable reciever?
I would HIGHLY recommend the Berg receivers. If you only need 4 channels, the stamp is among the lightest available, if you need 5, they make those as well. Great Rx's, and in my experience with them, very reliable and resistant to interference.
HTH
Jim
HTH
Jim
ORIGINAL: ald0cam
Cheers.
The only manufacturer that is different in the US is Futaba. The importers of Futaba chose to be different over here so they could force people to buy thier equipment. Glad the evil scheme failed.
