Futaba T7CAP Timer: Doesn't seem to work???
Reply
Old 09-27-2004, 11:14 AM
ChrisAttebery
My Feedback: (15)
ChrisAttebery's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba T7CAP Timer: Doesn't seem to work???
Hello,
I just bought a T7CAP. I'm setting it up for a trainer and I want the timer to work off the throttle. I followed the example in the manual but it still doesn't seem to work. The settings I used were:
Timer: INH (should this be set to off?)
Time: 10:00
Mode: Down
SW: 3 up arrow
I set the stick to 1/4 throttle and pressed the disk until it beeped. Got out to the main screen and moved the stick up and down, but the timer isn't starting.
Any suggestions?
Chris
ChrisAttebery is offline
Old 09-27-2004, 02:27 PM
Krysta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba T7CAP Timer: Doesn't seem to work???
Hi Chris,
Please see this thread from the Futaba Support group:
http://www.rcuniverse.com/forum/Time...2165881/tm.htm
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Krysta is offline
Old 09-29-2004, 12:32 AM
fritzthecat
fritzthecat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And after you read the above referenced thread, know that INH means the function in INHibited. You need to change it to OFF. Then set the throttle stick activation point. Check if the OFF goes to ON when moving the stick. Then check the aileron ATV settings to see if you have the software bug.
Fritz
fritzthecat is offline
Old 09-29-2004, 11:01 AM
ChrisAttebery
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Fritz,
Yep, I finally found INH in the glossary of the manual. Tried it again last night and it works fine.
Chris
