Reciver Antenna Cut
TX
Reciver Antenna Cut
I was removing a known good receiver from an airplane and accidentally cut approx 3 inches off the end. Range check on the ground seem fine but I am just not sure. Can I re-attach (solder) the broken end back on and keep going or would this be suicide? This is a hi-tech 7 ch standard receiver. The Pilot I have glued in the cockpit doesn't have an opinion. I think he will fly anything!! Any thoughts would be appreciated.
