Futaba 3305 & Battery question
ID
I asked this question in the Futaba support forum from which I received ziltch, so I will try here.
I have been following the various discussions regarding the high current draw of the 3305's. I am building a Ultra Stick 120 which will utilize 7 of these servos. How much battery capacity should I be planning on? I know I need NiCads, how big should they be to give decent flight times? I will be using 22 ga wire also...do I need larger than this? Thanks for your advice.
