Repairing 5925 servo wire
Reply
Old 10-07-2004, 09:10 PM
I & C Tech
I & C Tech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Repairing 5925 servo wire
A crash damaged the connector on one of my 5925's. I thought I would use an extension to make a new servo wire by cutting off the female end but I can't seem to get the servo disassembled down as far as I'd like to. I have the bottom cover off and can see the termination point of the wire and pulled the gears out of the top of the servo. I can't get the circuit board out to gain access to the bottom of the solder joints. Is anyone familiar with these that can lend me some advice.
I & C Tech is offline
Old 10-08-2004, 02:08 PM
EdwardB
EdwardB's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Repairing 5925 servo wire
I would really encourage you to put the servo back together. If/when you uncover the circuit board, you're going to find a small board with surface mounted components, etc. It's very easy to heat damage components, or to get something lifted off the PCB, with no chance to remount. There are several options to fix your damaged connector. If it's only the plastic housing, you can pop the pins out, and put on a new housing. There are also kits where you can get the pins, a crimper, and new housings and make a whole new connection, although perhaps slightly shorter if you have to remove damage. The simplest, low tech, way to repair is to splice in a new length of wire with the new connector, onto the existing pigtail coming out of the servo, using the piece of extension you described. Some solder skill is required, but much less than trying to solder new wires onto the PCB. Normally, when I splice a servo connection, I offset each one by about 1/4 inch, put a short piece of shrink sleeve over each, and then one piece of shrink sleeve over the whole splice. Works fine.
EdwardB is offline
Old 10-08-2004, 04:49 PM
I & C Tech
I & C Tech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Edward. I'm not bad at soldering but you're right about the board I suppose. Components are closely spaced and I'd hate to damage anything. I'll perform a repair per your suggestion.
