triple rates on futaba 9cap
Reply
Old 10-08-2004, 04:47 AM
ravenpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default triple rates on futaba 9cap
Hi,
someone can help me to setting triple rates on my 9cap?
Thanks[&:]
ravenpower is offline
Old 10-08-2004, 09:27 AM
Krysta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: triple rates on futaba 9cap
ravenpower,
The 9C is quite capable of triple rates, but only on the channel that has dual rates assigned to a 3-position switch. If aileron dual rate is assigned to C and elevator dual rate are assigned to switch G, then 3 rates are available for these channels, unless rudder's dual rate is ALSO assigned to the same switch as one of the other 2, a 3rd rate is not available for this channel because there is no switch position to trigger it.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Krysta is offline
Old 10-08-2004, 10:05 AM
ptgarcia
My Feedback: (36)
ptgarcia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I assign my triple rates for all surfaces to Switch C. Low rates to down position, high rates to middle position, and 3D rates to up position. This seems to work well for me. Good luck!
ptgarcia is offline
