Radio Choice
My Feedback: (13)
MA
Radio Choice
Hey im thinking of getting a new radio. I have been currently using a VG6000 which i loved but it dosent have enough memory. I would like a 6-9 channel remote with model naming, at least 8 model memory and preferabbly at least two three postition switches. Any ideas?
CA
RE: Radio Choice
Not sure what your price range is, but since you're already on positive shift, you might like to have a look at the new JR9303. It has 30 model memories, two 3-pos switches, two side levers, assignable switches and levers, a huge LCD display, flight modes, and for sailplane pilots like me, some great programming features. Comes in Air, Sailplane, and Helo versions with type-specific labels and switch/lever names. All 3 versions have the same programming inside. Only in Mode 2 for now, Mode 1 later. After looking at the Evo and other radios, I've decided to buy a 9303. Seems to be some intro offers in the $380-$400 range (Tx only with module). You can take a tour here:
http://www.horizonhobby.com/Tours
There's also the new Hitec Optic6 that supports both pos/neg shift and can be used with their Spectra synth module. Its quite a bargain for the money. Only 8 model memories though. Not sure about switches.
http://www.hitecrcd.com/Radios/OPTIC.htm
I'm sure others will throw in some suggestions for you to look at too.
Good luck!
Lance
Good luck!
Lance
SC
RE: Radio Choice
Futaba 9c is a real easy radio to program. but you need to find out what your club members are using the most of. That way you will always have help.
