Hi Voltage lines
Reply
Old 10-12-2004, 10:01 PM
plasticjoe
My Feedback: (22)
plasticjoe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hi Voltage lines
I am curious, those big high tension major power lines that run trough farm fields going to who knows where, do they put off any kind of RF noise to mess with the R/C Signal ? I am curious because there is a church that has a unique statue in my area that I would love to take pics of, but to do so would require flying close to those kind of lines ( less than 1/4 mile ) Wouldn't wanna put in a nice A/P plane and equipment from radio glitching. Your experiences would be appreciated. Thanks
plasticjoe is offline
Old 10-12-2004, 11:19 PM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hi Voltage lines
The dry lake where I do most of my flying has high voltage transmission lines running along one side. I've flown as close as 100' without any problems. I don't think it would be a good idea to get the lines directly between your transmitter and model though. This might be o.k., I've just never done it.
TimC is offline
Old 10-12-2004, 11:20 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Should be OK. Do an extended range check and see how the servos respond
rajul is offline
Old 10-13-2004, 06:32 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depends on the condition of the towers themselves. If they're in disrepair they may be generating a lot more RF than healthy lines. Like rajule said, just do a lot of range testing.
Lynx is offline
Old 10-13-2004, 06:48 PM
mr.rc-cam
mr.rc-cam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A problem as simple as a dusty HV insulator can create substantial EMI/RFI. As mentioned, perform extended range tests. And don't go out of your way to fly near the HV lines or towers.
RC-CAM
mr.rc-cam is offline
Old 10-13-2004, 08:16 PM
jpmcclary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A couple years ago we were having some "hits" in a specific direction from our flight stations. The distance from our flight lines was about 1500'.. I called the power Co to find out if there was a problem.. They said MAYBE... About a year ago they installed new towers and lines and upping the voltage... The problem STOPPED...Best guess, the insulators were causing the problem because they were warn/loose.
jpmcclary is offline
Old 10-13-2004, 10:11 PM
Flying Geezer
My Feedback: (14)
Flying Geezer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Many years ago I flew at a club field where one end of the field left you with the option of coming over, or going under, high tension lines. I had no problems, nor did I see any. Wave propogation is a complex thing. It IS a risk to fly near high tension lines, not only from the emissions, but several other factors. Avoid getting the power lines directly between receiver and transmitter. If you cross over the lines, try to keep the plane as broadside to yourself as possible, stay high, and don't point your antenna towards the plane.
Hope this helps. Good luck if you try it.
Flying Geezer is offline
