8u timer triggered mix
My Feedback: (12)
Is it possible to have a mix triggered after a certain time ?
I am interested in this because my fuel tank is near the
firewall and there is the obvious trim/cg change as the tank empties.
If it was possible to do some kind of fine elevator trim adjustment
to accomodate this.
L
to accomodate this.
L
IL
Sorry, Lenny, no. You could, of course, use your onboard timer to remind you to add trim every minute or so or you could create a complex on board CG adjustment that moved based upon a time delay setup.....or you could move your tank to the CG.
